Recommended 1000W motor for electric bicycle
Tonyr1084
Joined Sep 24, 2015
9,744
Well, a 2 inch pulley on the motor means you'd need a 23.2 inch wheel pulley. Might as well put a wheel on the motor and have the wheel rub against the tire since it's 26 inches.
shortbus
Joined Sep 30, 2009
10,049
That is the reason you see many things that use a Vbelt and needing a large reduction use a "jack shaft", when a gear box isn't necessary. Even stuff with a gear box, like a lawn tractor use a jack shaft or compound pulley to keep pulley sizes down and distance between motor and final drive more compact.
Another problem with using a very small and large V pulley is belt "wrap". The amount of wrap around the smaller pulley in degrees of angle. When you don't get enough wrap on a pulley you end up with more slip.
