Recharging my electric toothbrush's battery
Cretin
Joined Dec 13, 2012
69
Hey all,
My philips sonicare toothbrush's battery is dead. I don't have the charger, and am a student in electrical eng (2nd year) so I'm familiar with soldering and identifying positive/neg leads (basic electrical know how)
So take a look at the battery slot below and let me know if the areas I've identified are the positive/negative leads for the toothbrush battery.
If they are, then could i just look up the voltage capacity of the battery (and the type of battery as well), and simply hook up a power supply set to the required battery voltage, connect the leads to the battery on the points outlined in red above, and just monitor voltage while it charges the battery anew?
THE_RB
Joined Feb 11, 2008
5,438
Without the charger you do not know what the voltage is or what polarity it is.
I've pulled apart a few electric toothbrushes and normally they are 1.5v or 3v (one AA, or two AAA in series).
You should try to measure the polarity. If the battery has a tiny bit of sharge remaining you might get a reading on those terminals with a voltmeter.
Also keep in mind that the NiCd or NiMH battery inside that toothbrush will now be useless if it was left discharged for any length of time.
18,169
...could i just look up the voltage capacity of the battery (and the type of battery as well), and simply hook up a power supply set to the required battery voltage, connect the leads to the battery on the points outlined in red above, and just monitor voltage while it charges the battery anew?
Yes and no. Yes you could roll your own charger. But charging to a voltage, while OK for lead acid, is not a good strategy for other chemistries. A constant current trickle at 0.1C might be better, assuming you can find out what C is for your battery.
GopherT
Joined Nov 23, 2012
8,009
Why not look at other options first. I don't like seeing inexperienced people making things that plug into the wall and become fire hazards over time.
Try this for $12
eBay charger
spinnaker
Joined Oct 29, 2009
7,830
Try this for $12
eBay charger
Gopher has an excellent point. Nicads are notoriously a fire hazard. Just ask Boeing and those are some pretty smart cookies.
And not to mention a shock hazard in a bathroom no less..
As a very wise man once said "Penny wise and pound foolish".
Gdrumm
Joined Aug 29, 2008
684
Disaaasembly is the only way I know to discover what you are dealing with.
That said, you'll probably destroy the seals, and etc. when you do it.
Just spring for a new toothbrush, and tear that one down for fun.
You might find a suitable (same) charger on ebay as well, someone else perhaps with a dead battery in their unit trying to sell the charger.
To avoid further damage to your electric toothbrush, it is best to buy a new one. Soldering the device may cause more problems and may not solve the issue. If you do not have the money to buy the electric toothbrush, then you may use the regular toothbrush for the meantime.
