Hi All,
I’m trying to create a very simple circuit with one LED bulb which is battery-operated. (I know, this all sounds like LED 101)
There are several examples of this type on your site. However, I am looking for a bit of a different solution to my problem.
I had purchased some LEDs on Amazon in 2018 to create a proof of concept for a project. The one I am using is a 5mm 6v Pre-Wired Amber/Orange LED - Ultra Bright (3v, 4v, 5v, 6v) amber/orange LED, that I would like to power for very long periods (10 days at least). The LED I have is rated at 3v-6v, so my first attempt was to run this with a 5v battery pack, similar to the ones used to recharge cellphones. This works fine, but 99% of these charges have an auto-switch-off feature that turns off the charge if it doesn’t sense enough draw, which is the case with a 20mA bulb. The chargers turn off after about 30 secs on average (depending on the make).
Since this was not working, I then researched other options and came across some slightly different phone chargers, made by a company called VOLTAIC, which sells chargers of different capacities, all with a common feature of having the charger always on, no matter what the draw is. This solved my problem partially. The problem is that if I leave the LED on continuously, I will at most get about 2 and half days before the battery is completely drained. This surprised me given that the total battery capacity is rated at 6.4Ah*3.7V = 23.68Wh
From the manufacturer:
I’ve now recently been experimenting with small votive candles that run on a CR2032 battery and seem to be able to stay on for as long or longer actually. How can a coin-sized battery provide longer power than a big brick?? This is a total mystery to me. The LEDs are 3V on these.
So here’s my question, if anyone would be so kind as to help me answer, and so that I can keep the little amount of hair that I haven’t yet pulled out from the top of my head:
Is there a way to:
-Power a single Amber colored LED from a rechargeable battery.
-Be able to have that LED stay on for long periods. (10, 15 days)
-If only used for a few hours initially, be able to come back to a battery that has not drained after a few weeks of not being used (which happens with the current battery).
-Optional cherry on top: If the bulb could have a fading/breathing pattern, that would be tops.
Thank you for reading this far,
Any insight or help would be super appreciated. Any suggestions on a different approach would also be very welcome.
Cheers,
Fabrice
Here’s a picture of my latest set-up:
![Screenshot 2024-03-25 at 2.08.27 PM.png Screenshot 2024-03-25 at 2.08.27 PM.png](https://forum.allaboutcircuits.com/data/attachments/306/306204-fd27c415493e46aa966ae262f3b8b481.jpg)
Still, one would think that that tiny bulb could run for longer. So, I am not sure why this might be happening."The total capacity of the battery is actually the 6.4Ah*3.7V = 23.68Wh because 3.7V is the lithium ion battery cell voltage. The 5V USB output is the regulated output voltage and therefore is not the correct voltage to calculate capacity. Additionally, this is the nominal capacity assuming no losses. In practice we see that it is closer to 18-20 because of variation in the cells actual capacity, losses in the regulated output, and a low voltage buffer set at around 5% remaining capacity."
Is there a way to:
Cheers,
Fabrice
