ElectricSpidey
- Joined Dec 2, 2017
- 3,350
Yea sorry I did check the width but not the lead spacing.
I think what he is asking is that since we don't have schematic, have you measured the DC voltage across the power supply caps with the power on? A typical derating is that the cap rated voltage should be 25% over the actual designed/operating voltage. So if you measured 75VDC then the cap should be rated 1.25 * 75 = 94V (hence the 100V rating the manufacturer used).Mister i have looked can't find a build or repair spec sheet. Anthem has only given it to a couple repair places and those places won't talk about it.
That would require 54V peak + a couple of volts extra, so maybe 60V. 80V is probably a reasonable voltage rating for the caps.Power output: 180 watts per channel into 8Ω (x 5 channels)
If no information is available then you will need to apply power and measure the applied voltage at the capacitor. That should not require operation, but only powering the amplifier. But with all of the components connected.Mister i have looked can't find a build or repair spec sheet. Anthem has only given it to a couple repair places and those places won't talk about it.
Can link to them? I cannot find specs for that exact model.The amplifier specs say the output is 180 Whats with horrible 10% of clipping distortion or 100 Watts at low distortion, per channel into 8 ohms.
For a nonregulated power supply, the voltage falls as the load rises. So with only three of the amplifier modules connected it might be a bit higher. But it should be close enough to know if the 80 volt rating is adequate. There is no simple way to "listen" to a voltage level that I am aware of. You will need a voltmeter with an adequate range.If I only hook up 3 of the 5 modules would that lower the main rail cap voltage? Just wondering if there is ways to listen what these 80v caps would see? I'm sure there is part of this I don't know that controls the voltage the caps get.
