Realizing sinusoidally time varying resistance by digital potentiometer
shivashankar_p
Joined Nov 10, 2015
50
I need to implement a time-varying resistor for one of my studies. The Resistance must be of the form R=R0+Rm*sin(W*t), with R0-Rm>0. I am planning to implement this with a digital potentiometer (controlling it with a sinusoidal signal). I haven't tried this yet, and I am wondering whether this is a right way to implement this.
38,794
What resistive resolution do you need?
Obviously the sinusoidal signal would need to be in binary format to control the digital potentiometer.
How will you generate this digital signal?
Irving
Joined Jan 30, 2016
5,195
Is this a physical resistance or a theoretical one for use in a simulation?
Ian0
Joined Aug 7, 2020
13,275
How would that generate a sinewave change in the resistance value?
I should have mentioned it needs a dual pot.
One pot plus the comparator make a delta-sigma modulator. The other pot gives the variable resistance.
It requires the type of digital pot with a clock and up/down input.
shivashankar_p
Joined Nov 10, 2015
50
Thanks for the reply.
I am still not sure of the exact specifications. Mostly, I may choose a 5K POT with 256 steps for a maximum resolution.
I am thinking of using a Arduino for the digital sinusoidal signal.
shivashankar_p
Joined Nov 10, 2015
50
Thanks for the suggestion.
I am thinking of using an Arduino and a MCP41 POT. What do you think about that? It seems to be a simple and straightforward compared to UP/DOWN.
Irving
Joined Jan 30, 2016
5,195
Arduino + MCP41 etc. seems a reasonable approach within its limitations. Can you give more info regarding purpose of the 'resistor'? Also likely current & voltage levels?
38,794
To generate the digital sinewave, you could put a look-up table with 128 bytes of amplitude for a 0-90° sine into EEPROM storage (90/128 degree steps).
You can then use those to generate a 256 step DAC output of a 360° sinewave.
Ian0
Joined Aug 7, 2020
13,275
A few years ago, I would have written the code to reverse the first 128 steps for the second 128, then negate the first 256 for the second 256, and it would save be 384 bytes of memory. How much is 384 bytes of memory these days?
Now I think nothing of using a 4096 step look-up table with 16-bit coefficients.
38,794
I'm naturally conservative in using a micro's resources, but using a full look-up table is likely not a problem for most micro's today.
But since the TS it proposing using an 8-bit digital pot I see no reason to store more than one byte per step for 512 bytes total.
