real life circuit problems
hhsting
Joined Apr 25, 2024
395
Hello:
I am having trouble with the following circuit in real life. V1 is a constant 3VDC power source in circuit below. 30 ohms resistor in cirucit is led light 3VDC takes 100ma. It should turn on the led light when V2 is less than 0.5V. It should turn off led light greater than 0.5VDC. Does anyone have any luck real life assembling the circuit and turning light on and off with circuit below?
sghioto
Joined Dec 31, 2017
8,751
I don't have a PH2625L mosfet but did work changing the value of R1 with the circuit below.
Keep in mind the mosfet was fully ON with V2 at appx -.5V but full OFF required V2 at -.8V
Ian0
Joined Aug 7, 2020
13,279
Vgs(th) is listed as 1.5V typical, so why do you think it should be on at 0.5V?
Why do you think your LED should light up at 3.0V?
DickCappels
Joined Aug 21, 2008
10,661
And negative gate voltages at that.
Notice that these are enhancement type FETs, not depletion mode.
Just in case it is helpful, Vth is usually the voltage that causes some minor but defined drain current to flow, not necessarily full on.
35,186
I just noticed the negative voltage V2 on the gate input.
This is an N-type enhancement mode MOSFET. You don't need a negative voltage on the gate.
hhsting
Joined Apr 25, 2024
395
That still does not answer the question.
-0.5 V will turn off the MOSFET.
0.0 V will turn off the MOSFET.
+2 V will turn on the MOSFET.
How? How is voltage at gate negative?
You have (3 - (-0.5))/(R1 + R2). Where you see negative voltage at gate?
Alec_t
Joined Sep 17, 2013
15,156
It powers r3 which landscape lights 3vdc at 100ma
LED lights should really be driven with a controlled current; not by a fixed voltage. The forward voltage of an LED varies with the current and, because of manufacturing tolerances, supplying 3V does not guarantee that two samples of nominally the same type of LED will result in both passing the same current.
Can you post a link to the lights you will be using?
