RC Transmitter/Receiver
22,082
Until you have a working prototype I suggest you build it as designed. Once you have a working unit you can experiment with variations and modify the design. I'm assuming you do not have the test equipment budget or the RF engineering expertise to design and troubleshoot such a design from scratch.
s214519
Joined Dec 10, 2014
23
You're right, I really don't have any experience. Do you know of any place where I could get those sizes of enameled wire? I've been searching online but can't really find a good place to get it.
22,082
I always try Digi-Key first. You don't say where you are located so that may not be a helpful suggestion.
s214519
Joined Dec 10, 2014
23
I'm from a small town in Idaho. I went to the website for Digi-Key and they have tons of stuff. I'm just not really sure what I'm looking for.
Alec_t
Joined Sep 17, 2013
15,119
Or you could unwind a few turns from a scrap transformer or motor.
Edit: If you don't have exactly the same ferrite as the type the circuit designer used then the wire gauge is somewhat academic. A gauge approximating 0.3mm diam will probably be ok.
30,662
If that is 3mm dia that would be around 38awg, which you may get that off of a miniature relay if you have any, I suspect the gauge is not critical, within reason.
s214519
Joined Dec 10, 2014
23
I'm actually still in highschool and have always wanted to build an rc car as a project. I've built a few audio amps in the past and I've just been learning as I go. In this circuit, the interface with the relay is there so that I can run a higher voltage to a motor or whatever and it's just controlled by the recurve right?
30,662
You could also interface directly using a Mosfet at the O/Px and eliminate the relay.
Or a 2n7000 for the relay operator if needed.
s214519
Joined Dec 10, 2014
23
Here's another question. The interfacing relay is using a 2n2222 transistor. They are only rated for 900mA. I'm worried that if I run a higher amperage through it it will burn up. Would either of those ways handle higher amperage? Or is there a different transistor I could use that will work the same but is rated for a higher amperage?
s214519
Joined Dec 10, 2014
23
Max,
I did some reading, and correct me if I'm wrong, but I think a MOFSET would be the best way of going to handle higher amperage. But I also read that to do that and run higher amperage I would have to change the base amperage. Is that true? It would probably need to run around 6 amps.
30,662
The gate of a Mosfet requires a voltage as opposed to a bi-polar 2n2222 which requires base current.
IOW it does not impose the same load on the source using a Mosfet.
The IRL520/530 offers higher current capacity.
s214519
Joined Dec 10, 2014
23
So would I be able to just substitute an IRL530 for the 2n2222 to control the 12v motor? What else would I have to change in the interfacing relay circuit?
30,662
I couldn't find the spec sheet on the RX to find the exact nature of the output, but normally a straight substitute to the Mosfet is that easy.
You could take a 100k resistor from gate to common.
The only thing about controlling a RC motor this way, it is either on or off, no speed control.
