RC filter - Is this variation still RC filter
vol_
Joined Dec 2, 2015
93
In the image there is on the left a high pass filter. What I want to ask is if the left circuit is the same with the right circuit.
Thanks
SLK001
Joined Nov 29, 2011
1,549
The filter on the left is NOT a filter. It is the RIGHT image that is a high pass filter. The C and the R form a voltage divider, with the values of Xc and Xr. The image on the left is just a shunt resistor with a coupling capacitor.
vol_
Joined Dec 2, 2015
93
If the load resistance for the left circuit is equal to R2 and input signal source will have a low resistance, then yes, the circuit are the same.
http://forum.allaboutcircuits.com/threads/resistor-role-in-a-high-pass-filter.47449/#post-312336
Good to see you Jony. As always your answer is a reason for me to study.
I assume you meant "..load resistance for the left circuit is equal to R1", or not?
The load is the input of a TDA7052A IC. I measured with a DVM the input resistance connecting the probes on the input and signal ground. I got 0R. And i think that TDA7052 input impedance is set only externally (no info about input resistance in the topology og the IC) as in the next image:
I'm going to see in detail the thread you sent me, to understand how it fits my question.
Cheers
MrAl
Joined Jun 17, 2014
13,870
Thanks
To be perfectly clear, neither diagram is a circuit. A circuit is a connection of elements that form a complete loop where current flows.
Why i bring this up is because the two "circuits" are incomplete and therefore there is no way to come to a conclusion about what they can do. For example, if we short circuit the output of the first diagram, does it do anything? Maybe it does, maybe it doesnt. If it really was a filter maybe then it becomes a low pass filter.
If we use the output into another circuit that has some impedance, then maybe it becomes a high pass filter.
The interpretation also sometimes depends on the application it is used in. Maybe both circuits are just used as DC blocking circuits, and although they might still be called "high pass" the better description would then be "coupling circuit" or "DC blocking circuit" or something like that.
Capacitors in series usually form something like a high pass function but the whole circuit has to be known in order to make a good judgement about what it really is being used for.
Jony130
Joined Feb 17, 2009
5,601
No, I meant R2.
Externally ? No, we can find Zin in data sheet
Zi = 20kΩ typical and Rs is just a "pull down" resistor.
vol_
Joined Dec 2, 2015
93
Thanks, i like that you define the meaning of the word circuit and you count your sayings. Its the first time that i understand the word "circuit".
I wanted to know if there is a possibility the left circuit to be a filter, and so far the answer is yes. I now try to understand when and how.
Thanks
Jony130
Joined Feb 17, 2009
5,601
C1 (470nF) together with Rload (20kΩ for TDA7052) form a coupling circuit or a high pass filter with the corner frequency equal to Fc ≈ 0.16/(RC) ≈ 17Hz . and Rs= 5kΩ prevent the input from "floating".
vol_
Joined Dec 2, 2015
93
As i can get, if i would like the left RC connection to act same as the right RC connection and to be a high pass filter in a circuit, we want input signal source to have low resistance compared with r1 not to have attenuation of the signal in the sources' output and if the load resistance of the left circuit is equal to r2 (having c1=c2 uF) we will have the same frequency dependent voltage divider in both RC connections.
And expressing my question better, the left circuit it is not and it can not be a frequency dependent voltage divider as it is. It shall have a resistor path to ground to be one. Am i right?
Next question in next thread..
Jony130
Joined Feb 17, 2009
5,601
Yes, you are right.
Exactly.
MrAl
Joined Jun 17, 2014
13,870
Thanks
Hello again,
You're welcome. I said that mainly to draw attention to the fact that circuits that are not entirely complete are harder to define as to what they do when they are that simple. Some circuits are easier though and i see you do have the labels "IN" and "OUT" so that helps a little. I also wanted to bring attention to the fact that sometimes we call them a "coupling" circuit, and the capacitor is then called a "coupling capacitor", although in a wider sense it's still a high pass.
The difference between a coupling circuit and a high pass filter is found by looking at how they are usually used:
1. The high pass filter is usually used to get a specific kind of response needed for some filtering action.
2. The coupling circuit (or just coupling capacitor) is used mainly to remove the DC content in the signal, and not as strict on the filtering action although some attention is still payed to the cutoff frequency.
So we can say that the coupling circuit is a type of high pass filter, but it is usually not tuned as exact as a high pass filter is.
The main problem with the first circuit though is that we dont know what the load is, but most likely it is either used as a regular high pass filter or a coupling circuit.
vol_
Joined Dec 2, 2015
93
Oh yes, i was wondering about this. We still some attention to the cut off frequency but what do we substitute in f=1/2pRC equation for R if we have only a coupling capacitor in the signals path? Or the paths around the coupling capacitor will always have a dc resistor path to ground or a load?
Hello again,
Yes it was really a general question of me, trying to understand if there was any possibility for this circuit to be a frequency filter. Jony covered about these two RC connections and you gave me a more general enlightenment about capacitors ac use.
MrAl
Joined Jun 17, 2014
13,870
Hello again,
Well if you had this in a circuit there would be some output impedance from the first stage and some input impedance from the last stage, so if we say they were pure resistances for simplicity and we call the output resistance of the first stage R1 and the input resistance of the last stage R2 and our capacitor goes between those two stages, then we have:
w=1/(R1*C+R2*C)
as the cutoff frequency. That's the frequency that causes the response to drop 3db from the passband response, and the passband response is:
Vout=Vin*R2/(R1+R2)
Just to note, w=2*pi*f with f in Hertz.
