If you could build a dipole at the length of visible light wavelength, your "antenna" would be about the size of an atom. This is essentially what you have when an atom emits a photon...the wavelength is about the size of an orbital shell!I'm curious if you use oscillation to produce Radio Waves which are long waves to that of visible light...
What if your oscillation circuit produced short waves of the light frequency? would your capacitor/antenna start emitting light?
Isn't the color of the emitted light determined by the quantized "distance" the electron "falls" (shell transitions)?If you could build a dipole at the length of visible light wavelength, your "antenna" would be about the size of an atom. This is essentially what you have when an atom emits a photon...the wavelength is about the size of an orbital shell!
eric
E = hλ
where h is Planck's constant and λ is the wavelength.
This is known as Planck's Law
