andIt won't work if it is made on a breadboard becase the inductance ansd capacitance of a breadboard is too high for 100MHz. The wiring between parts must be very short. Use a pcb or a small stripboard.
The entire circuit must be insulated with a distance of at least 3cm from metal or a person.
Look at the datasheet of the transistor to see which leg is which.
The ground pin of the microphone is connected to its metal case. Look at it or use an ohm-meter.
I only built this circuit on a solderless breadboard. I can tap the mic and I hear a taping thru the speakers of the radio. But if I try talking into it it I don't hear anything. I have tried the mic both ways.audio guru was right. check the mic connections.you must have soldered it the other way round. take a multimeter and check the continuity between one of the two pins and the metal body.that will be the ground. it doesn't work then change the mic.
also check the battery. the battery should have full voltage.
Just to make sure though their is 3 green lines on one leg of the mic which are attach to the metal casing so this must be the ground leg going by your advice because the other leg doesn't seem to be attached to the mic caseing in anyway.
And so everybody knows I am working on this circuit
http://www.reconnsworld.com/transmit/fm_trasm.gif
So I can hear tapping thru the speakers so what could it be? if it truely is just that I have to trim the legs to fit tightly together I want to be positive. So I am holding off on this until the last resort. I thought I would eventually get it to work on a solderless breadboard before making it permanant.
The solderless breadboard is plastic so I would think it would work on this even if it doesn't work on a soldered breadboard.
Before I go any further I need to know what the difference between a PCB
or a small stripboard or solderless breadboard or soldered breadboard is?
Tommarrow I will plot the RF waves of the taping by plugging in my radio into my computer audio port.
But other then that I have know clue?
Maybe the graph will shed some light on the issue.
Does it matter if the condensor mic is omindirectional or unidirectional?
The only thing other then what we covered so far is the 4 - 40pf trimmer capacitor and 4.7pf capacitor.
I don't have these parts but I am wondering if using a 4 or 5 1pf in parrell for the 4.7pf and using different fix capacitor sizes for the trimmer is going to screw the whole thing in some way?
None of the items seem to need to be to precise and I don't think I would hear perfect tapping with no noise if I wasn't tuned in correctly. So if the 2 capacitors are not to much of the issue then I would say either I have a transistor in backwards or the components need to be trimmed and put closer together.
It is not the battery it is new and I checked it.
It maybe the mic I will try the mic out somewhere else as well as try a different one. But I really don't think this is it either. Unless I need some special mic which I don't think I need going be everything I read about mic's.
But maybe electert something totally different then a condenser mic?
