Radio Bands
biferi
Joined Apr 14, 2017
531
I do not know if anybody can help me with this but I thought I would ask?
If you are using a Shortwave Radio and you are Turning the Dial going from Station to Station every Station is spaced apart in 10 kHz increments.
Can anybody tell me what increments Stations on these Bands are spaced apart at?
VLF Band LF Band SHF Band EHF Band.
Thank you for all your help.
35,091
It depends on what you are transmitting and what sidebands are transmitted.
If your modulating frequency is 5kHz then you need 10kHz bandwidth on double side bands or 5kHz on single side band.
Ya’akov
Joined Jan 27, 2019
10,285
The spacing of channels in various bands is controlled by local regulatory authorities and international treaties. To know what the spacing is for any given band you will have to determine the service that it is allocated to, then read the regulations about channel spacing for that service.
There are a lot of services. This chart covers US allocations under the FCC. You will have to zoom in to see the text. Each service will have channelization, frequency band, and sometimes international agreements.
Externet
Joined Nov 29, 2005
2,667
'Shortwave' 3 to 30 MHz receivers can show AM, USB, LSB, DSB, FM, CW, FSK, AFSK, digital modes. Each can have its spacing. Amateur radio and military is not 'channelized' at fixed intervals.
Edited : Sorry; just noticed :
VLF = 3 to 30 KHz
LF = 30 to 300 KHz
SHF = 3 to 30 GHz
EHF = 30 to 300 GHz
As above said, each service has its regulations.
WBahn
Joined Mar 31, 2012
33,109
But...but...what about spread spectrum where all of the channels can be piled on top of each other and separated by means of their coding?
They still have regulations that govern spectral content.
In the U.S., in the ISM bands, unlicensed intentional transmitters were required to use spread spectrum, which is why the original 802.11 WiFi standard was based on frequency hopping and direct sequence spread spectrum (and also infrared). The same was true for 802.11b. But then the FCC the spread spectrum requirement, so 802.11g used OFDM.
biferi
Joined Apr 14, 2017
531
Well let say I had a Radio that can Tune in VLF Band.
As I move through the Band what will the spacing be between FREQ. this I what I should have asked?
WBahn
Joined Mar 31, 2012
33,109
VLF is too broad as it encompasses everything from 3 kHz to 30 kHz and is used for a variety of services, thus there is no single "channel spacing". Transmitters are given assigned center frequencies and bandwidths.
Try reading up on the things you are asking about:
https://en.wikipedia.org/wiki/Very_low_frequency#List_of_VLF_transmissions
biferi
Joined Apr 14, 2017
531
I think I understand how this works?
So LF Band would be the same?
The LF Band does not have Set Spacing as well am I Right on this?
