R/C car Controller
Wooooah there fella.
That Flysky is an airplane RC transmitter and uses a completely different frequency than the RC vehicles uses. If you start using it for RC vehicles you are gonna have a bunch of very mad RC fliers looking for you for interfering with their frequency and crashing their expensive and time consuming to build aircraft! And wanting your hide or money as compensation! Get an RC Car controller.
Frequencies for Radio Controlled Vehicles in the US (liveabout.com)
Correction I bought my fsI6x on Amazon it came with the 10 channel receiver the item description specified per my filtered search that this system was indeed suitable and designed for planes, gliders, boats, and land vehicles. The system has a binding key so that other systems “can not” intercept interference and interference from other devices “can’t cause” unwanted interference.
Ya’akov
Joined Jan 27, 2019
10,285
Welcome to AAC.
The FS-i6X, according to its Amazon listing:
FS-i6X Transmitter Specifications:
Channels: 6-10 (default 6)
Model type: Fixed-Wing/Glider/Helicopter
RF Range: 2.408-2.475GHz
RF power: <20dBm
RF Channel: 135
Bandwidth: 500KHz
2.4GHz system: AFHDS 2A / AFHDS
Modulation type: GFSK
Stick resolution: 4096
Low voltage warning: <4.2V
DSC Port: PS/2 Port
Chargeable: No
Antenna Length: 26mm (Dual Antenna)
Weight: About 400g
Power: 4 * AA battery (not included)
Display: STN transflective display, LCD 128*64 lattice, VA 73*39mm, LCD with white backlight
Size: 190 * 174 * 89mm
On-Line Update: Yes
Color: Black
Certificate: CE0678, FCC ID: N4ZFLYSKYI6X
FS-iA6B Receiver Specifications:
Channels: 6
Model type: Airplane/Glider/Helicopter
RF range: 2.4055-2.475GHz
RF channel: 140
RF receiver sensitivity: -105dBm
Bandwidth: 500KHz
Power: 4.0-6.5V DC
Compatible transmitter: FS-i6X, FS-i4, FS-i6, FS-i10, FS-GT2E, FS-GT2G
Antenna length: 26mm (Dual Antenna)
Weight: 16.3g
Size: 47 * 26.2 * 15mm
i-BUS port: Yes
Data acquisition port: Yes
KeithWalker
Joined Jul 10, 2017
3,614
Those of you who are stating that this system is not suitable for a land vehicle are stuck in a time warp. 20-30 years ago, Transmission frequencies in the 75MHz range were dedicated ti RC aircraft and 72MHz to land and water vehicles. There is no such separation of functions with 2.4GHz RC systems.
The Flysky FS-16X 2.4GHz GFSK transmitter and receiver combination is suitable for controlling model aircraft, boats and land craft. The transmitter is paired to the receiver in a way that will not interfere with other RC systems. The transmitter has a comprehensive array of setup choices in its software and can be used with differential powered steering (see mixing). To do that, you will need two drive motors each with its own reversible speed controller.
This is the manual for the transmitter. Make sure that you read and understand it:
https://static1.squarespace.com/sta...1567581800555/FS-i6X+User+manual+20160817.pdf
