Just a quick question that I'm sure one of the veterans here will be able to answer in their sleep. I've just had a chat with a friend of mine who used to do electronics as a hobby a while ago and he's said something that has confused me - either my understanding is wrong or he's rusty.
Now what he says makes sense kinda, but the way I see it, he's got the wrong end of the wire.
So, the question: if you have two circuits both with 9v batteries, and you put three LEDs onto the first circuit with a resistor there too, drawing 20 mA across each of the LEDs, and on the second circuit you have an individual resistor for each LED, which will drain the battery quicker?
The way I see it is, volts and amps are interchangeable, you can have 9v at 100mA or turn that into 18v at 50mA, or thereabouts, so when you put three LEDs in at 2v each, you're squeezing 6v out of the battery for the LEDs alone, and the resistor only squeezes 3v out of it. The current drain would only be 20mA. But with having three separate LEDs and resistors, you are using only 2v per LED and the resistors will be using 7v each. Each node will then use 20mA each, totalling 60mA - so the second battery will drain three times as fast as the first one.
Am I right in my reasoning?
