Quick question: Replace a capacitor for one with a little much higher capacitance?
spikespiegelbebop
Joined Nov 30, 2021
163
Hi, I'm working on fixing a circuit right now and I need a quick answer if possible: can I replace a 2.2mf capacitor with a 10mf capacitor?
Voltage is not a problem here.
WBahn
Joined Mar 31, 2012
33,288
First off, are you talking millifarads (which have the unit mF)? There was a time which mF was often used for microfarads, because µ was hard to typeset and because millifarad was a quite large capacitance. So if you are pulling the numbers of something old, it might mean either.
As to the question itself, no quick answer is possible. It depends entirely on what the purpose of the capacitor in the circuit is for. For many cases, using a 5x larger capacitor is just fine, but in other cases it would be better to use a smaller capacitor than a larger one. In other cases (such as if the capacitor is part of a timing circuit), you need to stay close to the original value. The parasitics of the two are going to be different and in many applications this won't matter at all, but in others it might cause all kinds of problems. Other parameters, such as ESR and leakage current, might be important (or might not).
WBahn
Joined Mar 31, 2012
33,288
The fact that it is in series with an inductor implies that it is part of a frequency-selective network and the value is pretty important. You need to replace it with the same size cap.
spikespiegelbebop
Joined Nov 30, 2021
163
Capacitor C510 looks like a critical component.
I would not replace it with 10μF.
In fact, I would replace it with 2.2μF 250V non-polar capacitor.
Are you sure it would work? I have way too many of them here. Mind showing me a picture of the one you're specifying, please?
Thanks, that clarifies everything.
BobTPH
Joined Jun 5, 2013
11,664
I can’t help it. The title of this thread bothers me every time I see it.
Substitute A FOR B
or
replace B WITH A.
Both mean take out B and put A in its place.
Poyntat
Joined May 24, 2022
60
The service manual indicates a value of 2.2uF 250V 20% electrolytic and it is not a safety critical component.
Why aren’t you replacing it with the correct value, they are available from eBay and other hobbyist suppliers as well as the usual professional suppliers.
35,249
The schematic shows 2.2μF/200V polarized.
We assumed that it failed once.
Hence the next one I would select would be 2.2μF 250V non-polarized if you can find one.
spikespiegelbebop
Joined Nov 30, 2021
163
I don't have a specific component to suggest.
What is the original package type, radial or axial?
Top is radial package. Bottom is axial package.
Here is an example of an axial package type capacitor.
https://www.newark.com/illinois-capacitor/225mpw250k/cap-film-pp-2-2uf-250v-axial/dp/84M4552
Datasheet
https://4donline.ihs.com/images/VipMasterIC/IC/CDUB/CDUB-S-A0013673942/CDUB-S-A0013673961-1.pdf
It's radial.
Weekend, no store opened, but I probably will end up buying one tomorrow anyway. It's just that I have a lot of spare parts here and the closest one that I found so far is a 10 uF capacitor.
