Quick basic questions about microcontrolers/microprocessor 8/16/32 bits
I can't think of many applications that actually use a UART these days. Certainly, anything to do with displays and audio wouldn't use the UART. If you can think of a valid application then it will be easier to explain.
:confused: I'm using a UART (using a DMA driver @460800 baud) to talk over Ethernet. There are still plenty of uses for a UART outside of being a debug channel.
https://forum.allaboutcircuits.com/...nd-sensor-node-for-canbus.189388/post-1797196
My current home project for the FM80 MATE monitor uses three uarts out of a possible five on the chip, SPI for the LCD and CANBUS-FD on an 8-bit PIC18 controller. MODBUS, FM80 MATE weird serial bus and serial to USB to upload data to the Linux server.
