Question / Help - XY Plot of a Level detector
Dieverse
Joined Feb 22, 2016
10
I am a student, and I am into my 2nd week of studying Op Amps. Yesterday we had our 1st lab and we briefly used XY Mode on the Oscilloscope for the first time and I am kinda unsure if I totally understand how XY Mode is displaying info........We now have an assignment and we have to draw the XY Plot for a level detector. Vin is 18 VPP the non inverting terminal is 5V and my power supply +/- 10 and thats basically all the info given..So I dont really understand what to draw???... Ive been searching google for a few days trying to find some info to help me, but cant really find what Im looking for....
AlbertHall
Joined Jun 4, 2014
12,626
The X-Y mode on a 'scope plots a graph of the two input signals, one against the other. so if the X input is the voltage across, say, a diode and the Y input is the current through it, then the 'scope will display the voltage/current relationship of the diode.
You are asked to draw the X-Y plot of a level detector. I presume that means draw a circuit which would display the plot on a 'scope.
One of the signals to plot is the output of the level detector but I don't understand what the other input is.
32,883
The other input to the scope is the input to the level detector. The problem very clearly shows that Vout is the y-input and Vin is the x-input. Vin is also clearly shown as the signal at the inverting input of the opamp and Vout is clearly shown as the signal at the output of the opamp.
32,883
So the op-amp circuit is the level detector, is that right?
Yep. Notice the wording of the problem: "... for the following level detector."
The use of the term "level detector" in the problem is just eye candy -- it could have simply said, "... for the following circuit."
Dieverse
Joined Feb 22, 2016
10
Thanks, but the problem wasnt what or where X & Y were or what Vin or Vout were, but was trying to figure out what to actually draw on the graph. Based on the info given Vout would be into saturation. So basically you have to draw a "Z" a straight line horizontally at 5v of the X axis and then straight across vertically at +/- Vsat.... ....
32,883
Hard to follow your description. Sketch what you are thinking and post it.
Dieverse
Joined Feb 22, 2016
10
Ok so the first image is an example from a power point slide (Bottom right shows XY plot for the circuit). 2nd picture is my assignment.... Part of the problem has been since the beginning of the semester we have had a supply teacher who just reads power point slides that the actual teacher made, and the power point slides are very vague. Another student and myself tried asking our supply teacher about some of the questions and even they said they were "unsure" what is being asked and would let us know monday (after she talked to the actual teacher..). The joke is this assignment is due tomorrow and then a test tuesday....We are supposed to have our actual teacher back soon. But its been a frustrating start to the school year.......
Dieverse
Joined Feb 22, 2016
10
Vout would depend on the gain. For calculations we use an ideal gain of 200,000 (as an Ideal op amp has infinite gain) So Vout = ED (the difference of V+ - V- ) x Aol (200,000) . So Ed = Vref (5V) - Vin (9v) = -4V Vout = -4V x 200,000 = -800Kv which isnt a real world scenario. Vout is impacted by the supply Vcc = +10 Vee=-10 ...So based on the prediction / calculation Vout will be Vsat
Dieverse
Joined Feb 22, 2016
10
Well that kinda my question, in what I actually draw. If you look closely you can see where my line started at -9 but I erased it....
AlbertHall
Joined Jun 4, 2014
12,626
If this was a real circuit, the input would go negative down to -9V and there would be a corresponding Vout.
Why do you think you should not include this part of the circuit's function?
32,883
It depends on gain no more than it does when Vin = 4 V. In that case you had no problem determining that the output would be +10 V. What is any different from this case and when Vin = 1 V or Vin = -1 V or Vin = -5 V or Vin = -9 V?
Dieverse
Joined Feb 22, 2016
10
My question was never bout the circuit or its operation I already stated this....My question was about XY plottting and what has to be drawn. My question was also whether drawing XY plot had any relationship to XY mode of a scope....Thats all. Nothing about the circuit.
In the end I figured out what she is asking for, Essentially its visually showing the predicted outcome. In this case being Vout is -Vsat when Vin is most positive.
