question about transistor resistor logic
MikeML
5,444
In retrospect, the 400uA makes it tough to do with a simple NPN (or with TTL or even LSTTL), I would use a 4000 series CMOS inverter.
34,824
You can get single gate components in a SMD package.
Or go with a single NPN transistor with two resistors as shown here:
The voltage source can be +5V instead of the +12V shown.
caoadon
Joined Jul 11, 2014
24
i just bought an NTE7404 hex inverter. Do i need to use resistors with them?
34,824
No need for additional resistors for your application.
You can use a single gate and leave the remaining five not connected.
If you want extra output power you can parallel multiple gates together.
400μA could be a limiting factor. Try it with one gate first and see what happens.
caoadon
Joined Jul 11, 2014
24
It seems to be inverting fine. Do I not need to do impedance matching? THeres a 50ohm input impedance.
caoadon
Joined Jul 11, 2014
24
Where exactly is the 50-ohm impedance?
The ultrasound im working with outputs a signal that i want to invert. so i sent it through the hex inverter. once inverted, the output of the hex inverter is the input of a laser with a 50ohm input impedance
MikeML
5,444
So this is an analog signal? If so, you need a medium fast modern opamp to invert the signal while retaining its fidelity; not a logic inverter...
caoadon
Joined Jul 11, 2014
24
Perhaps you should go into more details as to what you are attempting to do.
I am trying to invert a pulse and input it into a laser. The laser has a 50ohm input impedance.
I just bought a 7406 hex inverter open collector.
The 7404 didn't work. or it didn't invert the signal exactly (it was around a 2V pulse compared to the original 5V) because of the 50ohm impedance.
