Well i dont know, but i think it doesnt matter.What is the voltage across that resistor?
The question "What is the voltage across that resistor?" was meant for you to think about the problem and the answer.Well i dont know, but i think it doesnt matter.
I am learning how to semplify symmetrical circuits, and in the example i posted above the voltage was not mentioned.
You could use an eraser or white-out. You don't define what the result of deleting it should be.how can this happen?
how could we delete the resistance on the left?
Can anyone explain?
Oh i understand!! The voltage is 0V because C and D have the same potential thats why we can remove itThe question "What is the voltage across that resistor?" was meant for you to think about the problem and the answer.
It does matter. In the example posted, you do not need to be given the voltage. You need to determine this on your own.
Try to determine the voltage across that resistor and that will lead you to the answer to your original question.
Where is this educational material coming from?how can this happen?
Can anyone explain?
Yep, the clue was the word "symmetrical", that appears in the title of your thread.Oh i understand!! The voltage is 0V because C and D have the same potential thats why we can remove it
Thanks so much!
by Jake Hertz
by Jake Hertz
by Aaron Carman
by Jake Hertz
