I have a newbie question about replacing a battery in an older tablet.
It's an older Kobo Arc 10HD that recently has been exhibiting some random screen touches,
and I traced it down to a faulty battery that was bulging and generating pressure on the screen.
I took the battery out, it was a 3.7V 24.2Wh battery, and inside I found what I assume was a charge
controller to which each of the 2 cells of the battery was wired into, so basically 2 cells 3.7V each.
As a test I wired it into some 1.2V rechargeable batteries giving me around 3.6V on each side,
and that was wired into the original charge controller that I took from the original battery,
and I was able to run the tablet as well as charge it.
My question is if I get two 3.7V 3000mAh cells and wire them to the controller, would that be ok?
For example this: https://www.ebay.com/itm/173920590703?ViewItem=&item=173920590703
That should give me about 11.1Wh on each cell for a total of 22.2Wh.
Here's a picture of the original battery and also my test battery charging using 6 AA's ...
