Question about piezo buzzers.
Green Bean
Joined Mar 31, 2017
126
Why does a piezo buzzer still make a noise when a constant signal is applied? As far as I know, if there is no oscillator, there can be no frequency (because "frequency" is the frequency of the oscillating signal being applied to the buzzer/speaker) and therefore, theoretically, there can be no sound. However, when a constant signal is applied, it still beeps. Why?
AlbertHall
Joined Jun 4, 2014
12,652
A piezo buzzer has a built-in oscillator circuit.
A piezo transducer is just that and has no oscillator circuit.
Although the transducers are often called buzzers just to confuse.
This is the first I found on a search for 'piezo buzzer'. It is described as a buzzer and it says you need to supply it with a squarewave.
Caveat emptor.
ian field
Joined Oct 27, 2012
6,536
The buzzers have a small segment of metalisation on one side isolated to serve as a feedback signal - the oscillator can be as simple as a single transistor and a couple of resistors.
