I recently tried building a guitar pedal, but when i tested it i connected 9v from the battery to the circuit's ground pad on the PCB. It all started smoking, and all the components died. Is the PCB broken? How much heat can a PCB take before braking? When i solder, i sometimes have to put the soldering tip on the PCB for 30 seconds or so. Is that bad for the PCB?
