Question about Ninco electric longboard motherboard
Davidgo06
Joined Aug 16, 2021
13
Hello, recently someone gave me an electric longboard but I did not have the remote control so what I want to do is to start the engine when I press the switch, but I can't figure out how I can disable the remote control function so that the battery current goes from the ESC to the motor.
This is the motherboard .
If you need more information, please tell me. Thanks.
LowQCab
Joined Nov 6, 2012
5,101
Can You Plug the Battery directly into the Motor Connector ?
If You can, just add a Switch somewhere in line.
BobTPH
Joined Jun 5, 2013
11,615
Problem with that is that you are going to need speed control and probably a fail safe mechanism that the remote controls.
Bob
LesJones
Joined Jan 8, 2017
4,522
From the antenna on the PCB it is probably a wireless remote control. It is likely that if the remote control is out of range of the receiver the board will shut down as a safety measure.
Les.
Davidgo06
Joined Aug 16, 2021
13
Les.
But there is a way to start de engine by pressing the switch so the current goes from the battery to the ESC and the motor?
BobTPH
Joined Jun 5, 2013
11,615
Okay, let’s take a step back.
Do you intend to continue using the longboard or are you taking the motor out for a different purpose?
If you are going to use the longboard, how do you expect to control it while riding without the remote?
Bob
Davidgo06
Joined Aug 16, 2021
13
I will use the motor to make an electric scooter and I will put the switch on the handlebar so it is easy to start the motor
Davidgo06
Joined Aug 16, 2021
13
Hello, I had an idea but I don’t think is possible ,but anyway, can I connect a remote control of an rc car to this PCB?
BobTPH
Joined Jun 5, 2013
11,615
Depending in the type of motor, it may not run without the controller. And even as a scooter, it seems to me that you still need speed control.
Bob
LowQCab
Joined Nov 6, 2012
5,101
Start-out by gathering information ..............
How many Volts did the original Battery produce ?
How many Wires are coming out of the Motor ? (3 or 4).
Are there any small-Wires coming out of the Motor ?
What is the DC-Resistance of each Motor Winding ?
Take the Motor apart,
how many Magnets does it have, how many Coils does it have ?
Do You have a known good Battery that is very similar to the original Battery ?
Spend at least 5-hours searching for more information about the Motor online.
If You don't have any experience in creating your own Circuits,
just buy a used one that still works.
LesJones
Joined Jan 8, 2017
4,522
The ESC will be part of the main board. The motor will be a brushless DC motor. The thick green, blue and yellow wires will go the the motor windings and I think the 5 white wires will go to Hall sensors in the motor. One microcontroller probably performs the ESC function which will also control the speed and handles the communication with the remote control. I think the only solution is to buy a new remote control.
Les.
