Question About Magnetic Damage To Hard Drive
Glenn Holland
Joined Dec 26, 2014
703
I'm wondering why how close a permanent magnet can get to a hard drive before the field can cause damage to the data.
Every hard drive contains a strong magnet that operates the arm for the pick up heads and the field next to the disk is quite strong. However, the field must not have any effect or there would be immediate evidence of damage.
38,814
I believe the field from that arm magnet is fairly closely contained as there are two magnets which generate a very localized, closed circuit magnetic field the the arm magnetic coil works with.
An external magnet does not have a closed loop and thus could likely affect the magnetic disk from a significant distance.
DickCappels
Joined Aug 21, 2008
10,661
Has anybody ever heard of a hard drive being accidentally messed up by having a magnet placed nearby? If yes, what are the details?
Glenn Holland
Joined Dec 26, 2014
703
I asked the question because I had a foreign object stuck in my keyboard and I used a flashlight with a magnetic clip to light the area.
However, I kept the magnetic side at least 8 inches from the computer case. Obviously, if it caused any damage, I wouldn't be using my computer to post this!!! :)
