First question is about load cells. If they give me a 1m/V spec, that means that it will span 5mV with 5V excitation WITH RESPECT to ground? However, the whole span, with respect to the negative side would double (ie 10mV)?
Second, I have the AD8222 amplifier in house. I see in the spec sheet it says that the max voltage swing is (−VS + 1.1) to (+VS − 1.2). Does this mean that with a 5V supply, I cannot get a swing of more than 2.4V?
Bringing it all together, it would not be possible to take this load cell and use it with this amplifier to get .5 to 4.5V out with just a 5V supply?
