Question about gate driver specifications
geekoftheweek
Joined Oct 6, 2013
1,429
I would like to use the MIC5021 https://ww1.microchip.com/downloads/en/DeviceDoc/20005677A.pdf for a project, but having never worked with gate drivers before I have some learning to do.
Is the gate on voltage referenced to the circuit 0V (ground) or to VDD? I want to use a 50A capable FET, but most seem to need 10V above the source to turn on. VDD will be around 13 Volts from a car battery so the gate voltage would need to be 23 Volts to ground.
jpanhalt
Joined Jan 18, 2008
11,087
This:
Implies the boosted gate is relative to Source ≈ Vdd in a high side application.
And this muddies the water a little for that assumption:
However, the boost at 12V is only about 6V to 7V, which suggests that these values are relative to ground:
1604950942700.png.
jpanhalt
Joined Jan 18, 2008
11,087
The device is like ones I have used. It has a charge pump and goes above Vdd, but by how much? See the middle image (Figure 3-2) posted from the DS.
EDIT:
It appears the amount is about 50% of VDD (@36V increase is 39%, @ 12V, increase is 50%). Note 2 says at "DC". If that applies to the PWM, presumably at less than 100% duty cycle, it might be higher.
EDIT2:
I worried about that question, and here is the answer (Source: Datasheet):
Ian0
Joined Aug 7, 2020
13,264
The type you want is known as a high-side driver.
If you are driving it with a square-wave it can do its own charge pump.
If you look at circuits for half-bridge drivers such as IR2104, and IR2153 you will see the difference between the high-side and the low-side circuits, and how you can include a charge-pump
geekoftheweek
Joined Oct 6, 2013
1,429
That was what I was suspecting. I was thinking there would be some sort of notation if it was referenced to VDD, but maybe there was an "unwritten rule" I was missing.
I totally missed this in the datasheet. Thanks!
In all reality the circuit should only draw anywhere from 1A to 5A when working correctly. This is going to be a test device and I need a safety margin to allow for shorts to ground (one of the most common issues in the tested equipment) which is where the 50A thought came in. After a little more looking it looks like an IRLZ34 will handle things and with a .003 ohm sense resistor it should cut out at 16A.
geekoftheweek
Joined Oct 6, 2013
1,429
Another option I have is since I will be using a ‎MAX4173TESA connected to an ADC pin of a PIC microcontroller to measure current I could possibly use the PIC's PWM to create my own charge pump. If I connect to both an ADC and comparator of the PIC I could use the comparator to detect overloads and shut down the PWM in an interrupt. I'll do some experimenting there also.
geekoftheweek
Joined Oct 6, 2013
1,429
@jpanhalt thanks. I'll look around some more and see if I can find Microchip's information. I played with the idea before, but got lost in the math and since I really didn't need it at the time I didn't put a whole lot of effort into it. A gate driver sounds a little easier than trying to light a light bulb which is what I was trying the last time around..
