question about common base
Ghina Bayyat
Joined Mar 11, 2018
148
hi
i need a help in the common base configuration
i have this circuit below
i need to draw its ac equivalent model but i have a problem with inserting the hybrid pi model or any model because of rb1 and rb2
they are supposed to be in parallel but where to put them in the equivalent circuit i don't know
in fact the hole equivalent circuit isn't so clear to me i find it difficult compared to the common emitter equivalent circuit
i know it's wrong but will it look like this ??
Ghina Bayyat
Joined Mar 11, 2018
148
WAIT
that's right i almost forgot they are gonna be shorted because they are connected to grounded base and also the other end of rb is connected to shorted vcc
32,840
what do u mean what does it look like ? if i knew i wouldn't ask i didn't know how to draw the equivalent circuit
do u mean what is the circuit's behavior or something like that ?
It's going to always be very hard to draw AC equivalent circuits (better known as small-signal equivalents) if you don't understand the major functions of the parts of the circuit, if for no other reason than you don't know which components do and don't get included in the equivalent circuit, let alone why they do or don't.
What's the purpose of Rb1 and Rb2? It's to set the DC bias point of the transistor.
What's the purpose of all of the capacitors? It's to separate the AC operation of the circuit from the DC operating point. As such, they are chosen so that their impedances at the frequencies of interest are low relative to the other impedances.
In particular, Zcb << Rb2. So what does that imply about the base of the transistor at signal frequencies?
Ghina Bayyat
Joined Mar 11, 2018
148
this means that the resistors connected to the base won't affect the small signal and it won't pass through them so in this case they won't get included in the small signal equivalent circuit
MrAl
Joined Jun 17, 2014
13,704
Unless you need to analyze for frequency response.
MrAl
Joined Jun 17, 2014
13,704
no i don't but why would it change for frequency response ?
resistors are elements that don't affect the frequency
Oh, i was talking about the capacitor which changes the frequency response as i think you already understand now. Probably not too significant for your exercise though, but only you can decide that.
Ghina Bayyat
Joined Mar 11, 2018
148
i thought u were talking about rb1 and rb2
MrAl
Joined Jun 17, 2014
13,704
Well depending on what model you are using (if it contains any capacitance) all of the components may alter the frequency response. I was talking about the most significant.
As i said though it may not be relevant to your problem.
