Question about battery and resistance circuit
Boe
Joined Jan 6, 2018
7
A battery has an internal resistance of 0.5 ohms . The battery has an emf of 1.25 v .
When it's connected to a resistor ,the terminal voltage falls to 1.45 v.
what is the current flowing?and what is the value of the resistor?
can you guys tell me the steps of solving this q ?!
Reloadron
Joined Jan 15, 2015
7,977
You are stating a battery has an open circuit voltage (no load) of 1.25 Volt and then when a load is placed on the battery the voltage increases to 1.45 Volt?
Something isn't right here. How does the open circuit voltage increase under a load?
You may want to give this a read as it explains things well and again when a load is applied affording a current flow the battery voltage should decrease and not increase. When we apply Kirchoff's laws we just manipulate the formulas, including Ohm's law.
Ron
Boe
Joined Jan 6, 2018
7
Ron
thanks bro that was helpful
BillB3857
Joined Feb 28, 2009
2,573
This site will be a great help to you by guiding you as to how to solve the problem. Folks here DO NOT do your homework for you. You wouldn't learn much that way. Now, assuming you have the voltages reversed in your original post, what if you had an ideal voltage source (one that will hold a constant voltage no matter what load is placed upon it). What if you placed a 0.5 ohm resistor is series with it. Can you take it from here?
dl324
Joined Mar 30, 2015
18,501
yes it is ,
Does it not allowed here ?!!
Homework questions are definitely allowed, but they belong in the Homework Forum. In that forum, members know not to simply provide answers.
I always ask if it seems like a homework question because you'll learn more from doing the work yourself or being helped versus someone thinking they're being helpful by just supplying an answer.
Audioguru
Joined Dec 20, 2007
11,248
Dyslexia causes numbers and letters to be mixed up.
At first I thought a battery that measured only 1.25V could easily be a cheap Chinese "Sooper Heavy Dooty" one and almost dead with an internal resistance of 0.5 ohms.
Then I also wondered about the magic (heating?) that causes its voltage to rise when loaded.
