Question about 4093 oscillator
JavaLi
Joined Jun 24, 2017
8
The breadboard examples is wrong, missing resistors, etc..
To calculate the output frequency is fo = 0.8/RC...
Search more for Schimidt Trigger.
Best regards.
Audioguru again
Joined Oct 21, 2019
6,826
What a messy tangle of wires all over the place! How can you see which connects to what?
What is your output, an LED or an amplifier?
The Fluxmonkey article shows that the red thing in the breadboard is a resistor standing up.
Audioguru again
Joined Oct 21, 2019
6,826
NO. The red thing on the demo breadboard circuit is said to be a resistor standing up, they say try 100k, not an LED.
With a 100k resistor and a 0.01uF capacitor then the RC makes an audio tone into the input of an audio amplifier (not a speaker) and it will not be powerful enough to feed an LED.
javi.electronics
Joined May 13, 2020
9
I'd call that a cartoon.
Here's a schematic of what the cartoon depicts.
It can't work.
I see two pots in your pictures, so the cartoon isn't what you wired. It would be helpful if you posted a schematic for what you wired.
I understand the meaning that I use 2 pots. The main reason is because, the first one doesn't work so, I was looking if, it's a problem in some place if, I work the 2nd oscillator. It was not possible withe first too.
javi.electronics
Joined May 13, 2020
9
Yes, I tried with a potentiometer that's the same that a resistor but, it doesn't work.
javi.electronics
Joined May 13, 2020
9
What's the difference in to start to work the audio between an amplifier and a speaker?
dendad
Joined Feb 20, 2016
4,641
When I do breadboard protos, the wire to use is solid single core from an old bit of telecom cable. Ethernet cable works well too.
Then trim the wires to fit, so it is easier to trace.
Here is an example I just tossed together.
And, if you phone has a Macro setting on the camera, use that for better close ups.
By the way, this flashes the LED.
Audioguru again
Joined Oct 21, 2019
6,826
A CD40xx IC has a low output current of about 15mA when it is powered from 9V. Then it can produce 5V to a 333 ohm load because 5V/15mA= 333 ohms. The input resistance of an amplifier is thousands of ohms so it works fine.
Now see how much output voltage the 15mA will produce in an 8 ohm speaker: 15mA x 8 ohms= 0.12V which is not enough voltage to let the oscillator work.
javi.electronics
Joined May 13, 2020
9
Thanks a lot really, you had reason with it. It works now. Just I would like to add a volume + a kind of simple effect. Could you to help me with a schematic?
dl324
Joined Mar 30, 2015
18,403
Sure looks like an LED to me. Note how the right side has a "flat" edge. They were detailed enough to show the bare wire ends. You'd think they could show a wire coming out of the top of a resistor that was standing up.
My advice would be to never trust a circuit from someone who draws cartoons.
