Easy - a pulsation filter!to remove pulsations from a power-supply output what kind of filter should be used?
For this, you would usually use a electrolytic capacitor. Although, you will need your diode bridge to rectify the AC. The capacitance value will depend upon the current output needed.to remove pulsations from a power-supply output what kind of filter should be used?
