Query about BLDC driver Project not drawing power
Lawrence White
Joined Jan 7, 2019
8
Evening all,
FTP, so excuse any rubbish formatting.
TLDR: I have an issue at the moment where a BLDC driver i am making isnt drawing anywhere near the current it requires from a battery.
so i have 3 half-bridge set up running a 3 phase BLDC motor, you know the type...
I have code written up an verified to be working for the arduino, and its suppose to turn on the respective logic-level mosfets for each phase depending on the motor position (i can use the hall sensors or BEMF as i have a couple sets of code).
The logic-level Fets state i can use the 5V from arduino digital pins to turn on the Fets, allowing current through to turn the motor.
HOWEVER.If i use a lead acid battery, it only draws about 0.5A into the circuit (fair enough ,its only rated for 1.05A initial), but i do get resistance if i manually turn the wheel whilst the driver is running. If i use the battery i want to use (ebike/hoverboard battery - stated below), then it doesn't draw at all, whereas i know these are working as i can pull them right off and plug them into their proper devices, and they work (hoverboard and e-scooter), and they work no problems. i have multiples of each battery i can use.
now, ive looked at the devices ive pulled these from and had these batteries working, and confirmed charged. the main boards and ebike controllers have the v+/v- from the batteries connecting straight to the high and low sides of the gates, so i know that they should work.
thinking it is an issue with how im controlling the Fets?
Any ideas how i can resolve this to draw what its meant to be using?
Thanks to all who can help me...im stumped on this, i may be an amateur, but i know my stuff, or not as it seems!
see attached for schematic, excl. all sensor components.. excuse my appauling use of the software, still learning it.
components used are:
Hoverboard BLDC Motor - 350W BLDC
only working source - Lead acid battery - ''6fm3.5'' - 12V/e.5Ah - 1.05 initail current (stated) -http://images02.cdn86.net/kps01/M00/6A/4A/wKiAiVWZ5sLPAerCAA2ljvtaRgc979.pdf
desired Hoverboard Battery pack- 36V/3.4Ah/122.4Wh - (basicly 7x 18650 cells)
desired ebike battery pack - 36V/3.4Ah/144.4Wh - (basicly 10x 18650 cells with BMS)
Logic level Mosfet - RFP30N06LE - https://www.sparkfun.com/datasheets/Components/General/RFP30N06LE.pdf
shortbus
Joined Sep 30, 2009
10,049
I may be wrong about this, correct if I am. You have a hoverboard motor, hoverboard battery, why not use the hoverboard controller? Even if your putting it in an Ebike, why reinvent the wheel?
Lawrence White
Joined Jan 7, 2019
8
Yeah, i agree. in fact, i will be doing that with one set of the parts as part of a toy for my children.
i just wondered if i could do it to be honest, and see if i could put it to use
Sensacell
Joined Jun 19, 2012
3,789
Your high-side N-FETs need a gate voltage higher than Vcc to turn them on.
When they turn on, the Source terminal rises to Vcc, to get the correct V-gs, this implies a voltage higher than Vcc.
Investigate using gate driver IC's- with gate boot-strapping circuitry.
The Aurduino I/O pin is not very good for driving a MOSFET gate at any decent frequency; the gate looks like a large capacitor that needs to be charged and discharged rapidly, it requires high currents during the transients.
shortbus
Joined Sep 30, 2009
10,049
Do you know there is an 'old school' way of doing this? But it requires a BLDC with Hall sensors. https://www.onsemi.com/PowerSolutions/product.do?id=MC33035 If you do a search for that part you can also find an Application Note that walks you through using it.
Lawrence White
Joined Jan 7, 2019
8
thanks for the reply! So, its safe to say that if i have a supply of 36V from the battery to the high side, i need to apply minimum 36V+V(gs) to the gate of the respective fet?
thanks for that... ive just spent a few minutes browsing the data sheet and some pre-built boards with this IC, looks promising, may invest in a couple to simplify some projects. However, i would like to eventually create the drivers myself. 'Thrill of the chase' type thing.
plus I'm learning so much!
Lawrence White
Joined Jan 7, 2019
8
Also, i need to re program the GD32 chip on it, aannddd i cant afford the £75 for the GD-Link USB interface chip. ST links are cheap and work, but not with GD devices.
it gets speed and direction instructions from 2x accelerometer daughter boards via UART, which i simply dont have the ability to de/encode directly on. however, i planned to re-program the GD32 to use a simple potentiometer to determin speed like a foot/twist throttle. hence the chip.
if i could use an arduino to read 2x Pot~s and encode the inputs from them both to UART and send to the board, then fantastic, but i dont know what specific protocol that the GD uses unfortunately.
