MaxHeadRoom
- Joined Jul 18, 2013
- 30,869
The circuit you show in #20 is the one I use with a 10k pull up into a Pic input.
What are you inputting to?
Max.
Max.
That may be adequate to detect a black mark on the spindle when a mm or so from it. Have you tried that?This is what I have so far. Instead of the 10k, I am using 560K. I get 0 to about 2.4v on out with about 320 mv of ripple off of zero. Can I do better? My supply is 5v. And I went with 180 ohms for the current limiter
I don't see why you are concerned about what the device does with your hand or a white sheet of paper in front of it?
Why did you increase the current limiter resistance? That will reduce the LED output light and thus the output signal level.
The LED has a maximum current rating of 50mA, and 100Ω gives about 38mA with a 5V source, which should be a good value.
I would go for the retro reflective tape. Good tape makes white snow look gray in comparison. Maybe put black crepe tape on the spindle with a strip of the retro tape on top of it. That would give about the highest contrast I can think of.I have used these for a digital tach with a pic, just white paint or 3M retro reflective tape.
With the retro tape and less than 1mm of gap I doubt that you will gain much with an IR filter.
The users of the spindle controller in post #19 just used a white paint mark on the spindle shaft.
I think I have a spare QRE1113 around, if I find it I will do a little testing.
The 3M 'Scotchlite' product is quite a common product, should be available from hardware stores or safety supplier, I keep some for putting on shafts to use a hand held digital tach unit.
Max.
The unit was on sale initially as a promotion so I picked one up, mainly for assessment purposes, It worked pretty good but the Mk1 did not have the temp indicator of the Mk11.So you purchased TheRB's controller? Or you were able to buy the sensor? If so where did you get it?
Does it have a temperature sensor too? Display seems to show temperature. Might be an interesting addition to my project since I have a number of those Dallas sensors around.
As Max said you can get retro tape at hardware stores. Lots of variation from brand to brand. Chose the one that is whitest when looking at it with the light directly behind you. The best way of doing this is to hold a flashlight against your temple.Where do you find "retro reflective tape" and "black crepe"?
Oh, and I wouldn't be self-conscious at all doing that!The best way of doing this is to hold a flashlight against your temple
It's better than a gun.Oh, and I wouldn't be self-conscious at all doing that!
I got over that a lonnnnnng time ago. I can now walk up and down _all_ of the aisles of a Jo-Ann's fabric/hobby store with all the women looking my way and not blush a bit.Oh, and I wouldn't be self-conscious at all doing that!
