Hi again.
MrAl, I will try to respond to some of your statements/conclusions.
Quote: "Then ask yourself why i would think it did. "
Yes, thats what I did several times. But I did not find an answer. I think, it is YOUR turn to convince me that you are right - or to proove that I am wrong.
Quote: "But i have to comment slightly here. You have given me an equation with no variable or symbol Q in it and asking me if there is a Q in it. That implies a few things.
First, that you are defining the Q of a filter based on what a first order filter equation has in it."
No - that is wrong. At least 4 times I have mentioned that there is a definition that was agreed upon since several decades.
I did not define anything. Shall I repeat again?
It is the POLE POSITION which is used for defining the Q-value of a second-order lowpass.
The fact that it does not appear in the 1st-order equation is the RESULT of this definition (because it applies for a pole pair only) and not the definition itself.
Quote: "Second, that means that you cant understand how something can have a Q when it is not in the equation."
Wrong conclusion. The absence of Q in the 1st-order equation results from its definition. Thats all!!
Quote: Ok so we have established that you are defining the existence of a Q by what an equation has in it, if it has it then it has a Q, if it does not have it then it does not have a Q.
Wrong conclusion (see above)
Quote: That is because we are seeking a method to figure out the Q of different filters, without resorting to old fixed definitions, if it even is one.
What this leads to is a more general definition of Q apparently, but to be honest i dont think it is actually new because it appears elsewhere also.
Also wrong - as far as my person is concerned. I am not seeking a new definition. Such a new and "more general" definition appears "elsewhere"?
Up to now, this is an assertion only - unless you give me a reference. I never have heard about it....
Quote: "Take two first order LP filters (that dont have a Q because it doesnt exist for first order filters) and connect them in cascade and you get a 2nd order filter with a Q of 0.5."
Does that sound right to you, because it does not sound right to me. It seems more logical that the two first order filters must have a Q of something.
Yes - it sounds right to me. And the explanation is simple (and will be no surprise to you):
Two first-order filters in cascade form a second-order filter - and now the Q-definition is applicable because we now have a pole pair!!
Quote:
"Corollary:
If we wanted to compare two filters with unknown topology let's say these three:
1. Q=0.5
2. Q=1.3
3. Q=5
We can see right off that #3 has higher Q then #2 and that has Q higher than #1.
Also, because the Q of #2 and #3 is above *0.5* (the star of the show) we know they must be of 2nd order or greater.
No - again, you have not the right understanding! A Q=5 is a second-order filter (Chebyshev response) with a large peaking of the amplitude before the passband ends. Again and again: Q-values for lowpass filters are defined for 2nd-order only.
As an example: A lowpass with Q=1.306 is a Chebyshev filter (2nd order) with a peaking (ripple) of 3 dB.
More than that , this touches my question you still have not answered: When you are speaking of Q for higher orders - WHAT IS YOUR DEFINITION?
Quote:
"The next simple question is, what order is #1?
Now if you want to say that ti *must* be 2nd order because a first order can not have a Q because it does not exist that's fine, but i cant agree with that for the following reason (with this example only):
We could be referring to a first or second order filter with item #1 to keep the list shorter. If we did not do that, we''d have to list like this:
1. Q=0.5
2. Q=1.3
3. Q=5
4. Q does not exist
Granted that takes the ambiguity out of it."
I must admit - I do not understand the logic behind it....can you explain where you see any "ambiguity"?
Quote:
Let me state this point another way...
If we are discussing what kind of filter to use for a given application, the dialog may go like this:
"Hey Dexter, what kind of filter should we use for this new product?"
"Well Henry, do you think we should use a filter with a Q of 4 or a Q of 7, or how about a filter that does not have a Q because it does not exist?"
"What? We just need a reasonable sharpness and we know that correlates to the Q of the filter, so how sharp is the filter you say has no Q because it does not exist?"
"Gee Dexter, i cant tell because it has no Q because it does not exist."
"Well then how do we know if it has a sharp enough response for our needs?"
"I guess we dont, unless of course you would like to assign a Q that correlates to the sharpness of the response, even though the Q does not appear in any formulas yet."
"Oh ok that sounds reasonable, then we could tell the difference when comparing filters."
"Ok as long as everyone agrees then we'll do that."
"Ok. By the way, my name is not Dexter it is Qdexter."
"Oh gee, sorry i was under the impression that the Q did not exist."
"Ha ha, very funny, so being Henry, i guess you are an inductor then?."
<Henry quietly walks out of the room>
Although the above is a little funny, it makes a point about comparing filters with regard to Q."
I must admit that this dialog is really crazy (not really funny).
The first answer from Dexter (3rd line) shows that he has no idea about filter design; he even does not know how to specify a filter. Thats all I can say to this part of your answer.
Again - please answer my question. Several times you have mentioned that there is a Q-value even for higher-order lowpass functions. And this means: You must have a definion in your mind. Why don't you enlighten me and give this definition?
Finally, if my choice of words seems a little rude at times, then I'm sorry.
I do get a little impatient when I have to repeat my arguments again and again ....... and you neither accept nor disproove it.
Regards
Quote:
"Corollary:
1. Q=0.5
2. Q=1.3
3. Q=5
1. Q=0.5
2. Q=1.3
3. Q=5
4. Q does not exist
Regards
