Q in loop current method ....
33,325
Well, since you don't bother to even define what i2 and i3 are, how do you expect anyone to be able to help you find them?
Since this is Homework Help and not Homework Done For You, you need to show YOUR best attempt to work YOUR homework. It doesn't have to be complete or correct, but if you don't show use your efforts, it makes if very hard for us to tell where you are having problems and to help you overcome them.
33,325
Why do I have the feeling that "found the answer" means just what it says -- that you found a solution worked by someone else? Oh well.
Using a supermesh is certainly one way, but not the only way. A trivial rearrangement of the parallel branches yields a circuit that has three meshes, one of which is trivial and the other two of which are just ordinary meshes.
