PWM using controller
RenesasT1
Joined Jul 6, 2017
107
In fact, My BOM has been finalised so I can not be able to change controller ATtiny10. I think you are aware of this. Also the major issue is, ATtiny10 has only one 16 bit timer.
Awaiting for your comments.Also awaiting for your private message.
jayanthd
Joined Jul 4, 2015
945
I have ordered PCBs for ATTiny Programming adapter and ATTiny10 Breakout boards. I will get them in 15 days. Till then I can't do any think. After 15 days I have to get the components soldered to the PCBs. Then only I can do some testing.
jayanthd
Joined Jul 4, 2015
945
Have you received?
Hi
I have not received. OSH Park sent the two different PCBs (programming adapter board and attiny10 breakout board) in different packages and the local delivery person stole one of the packages which contained the attiny10 breakout boards. I had ordered 3 PCBs each. The local delivery people here are not good. They come from slums and they steal parcels which come through free shipping methods.
I can't order again.
Any other option you have ?
Do you have a working Proteus ATTiny10 model so that I can help you ?
jayanthd
Joined Jul 4, 2015
945
Please zip and post the ATTiny10 CodeVisionAVR project which I gave you in another forum here. I will try to test the code in a different way.
jayanthd
Joined Jul 4, 2015
945
Any alternate method you have to test the ATTiny10 project which you can tell me so that I can try it ?
Proteus ATTiny10 model is not working.
RenesasT1
Joined Jul 6, 2017
107
I have ATtiny microcontrollers mounted on zero PCB. I can implement your code and can see the waveform.
But, ATtiny 10 does not support on chip debugging.
jayanthd
Joined Jul 4, 2015
945
Code is not changed. I need to test my code to see what is the problem using scope. I have Oscilloscope.
Can you build the final hardware and send 1 unit to me. I will use it for developing and testing code. I can pay for it but you have to bear the shipping charges or you can send it through registered Air Mail. I am from India.
RenesasT1
Joined Jul 6, 2017
107
What we can do is, I can show you the video clip of the problem by today evening from which you can see the exact issue.
Please acknowledge the same and give me your working whats app number.
jayanthd
Joined Jul 4, 2015
945
Ok. Send the video through email. PM me and I will provide my email ID in PM. I don't do Skype or WhatsApp.
