PWM using controller
RenesasT1
Joined Jul 6, 2017
107
Hi jayanthd,
I have selected below ,
C=0.1 uF ceramic i.e 100nF ceramic.
R=1.6kohm
But I am getting same fluctuations. NOt getting proper DC o/p.
LesJones
Joined Jan 8, 2017
4,511
The idea is that the low pass filter will NOT allow any of the input frequencies to pass. I chose 5 Hz as it will average over 10 cycles of the lowest expected input frequency (50 Hz). I would choose a resistor value of about 10K. The microcontroller will be seeing an analogue voltage which is the average value of the PWM waveform.
Les.
jayanthd
Joined Jul 4, 2015
945
Les.
2.7 UF or 3.3 uF ?
ArakelTheDragon
Joined Nov 18, 2016
1,366
Everything is possible :D.
But you will have to initialize the ADC module and the PWM every time you want to switch from 1 to another, this will take more RAM.
Take a look at this source code with the CCS PIC C compiler from ccsinfo.com
Code:
// DC motor control using PIC16F877A CCS C code
#include <16F877A.h>
#fuses HS,NOWDT,NOPROTECT,NOLVP
#device ADC = 10
#use delay(clock = 8000000)
#use fast_io(B)
#use fast_io(C)
unsigned int16 i ;
void main(){
  port_b_pullups(TRUE);                  // Enable PORTB pull-ups
  output_b(0);                           // PORTB initial state
  set_tris_b(7);                         // Configure RB0, RB1 & RB2 as inputs
  output_c(0);                           // PORTC initial state
  set_tris_c(0);                         // Configure PORTC pins as outputs
  setup_adc(ADC_CLOCK_DIV_32);           // Set ADC conversion time to 32Tosc
  setup_adc_ports(AN0);                  // Configure AN0 as analog
  set_adc_channel(0);                    // Select channel AN0
  setup_timer_2(T2_DIV_BY_16, 250, 1);   // Set PWM frequency to 500Hz
  delay_ms(100);                         // Wait 100ms
  while(TRUE){
    i = read_adc();                      // Read from AN0 and store in i
    if(input(PIN_B3) == 1)               // If direction 1 is selected
      set_pwm1_duty(i);                  // Set pwm1 duty cycle
    if(input(PIN_B4) == 1)               // If direction 2 is selected
      set_pwm2_duty(i);                  // Set pwm2 duty cycle
    delay_ms(10);                        // Wait 10ms
    if(input(PIN_B0) == 0){              // If RB0 button pressed
      if(input(PIN_B3) == 0){            // If direction 1 not already selected
        output_b(0);                     // Both LEDs OFF
        setup_ccp1(CCP_OFF);             // CCP1 OFF
        setup_ccp2(CCP_OFF);             // CCP2 OFF
        output_c(0);                     // PORTC pins low
        setup_ccp1(CCP_PWM);             // Configure CCP1 as a PWM
        output_high(PIN_B3);             // RB3 LED ON
    if(input(PIN_B1) == 0){              // If RB1 button pressed
      if(input(PIN_B4) == 0){            // If direction 2 not already selected
        setup_ccp2(CCP_PWM);             // Configure CCP2 as a PWM
        output_high(PIN_B4);             // RB4 LED ON
    if(input(PIN_B2) == 0){              // If RB2 button pressed
      output_b(0);}                      // Both LEDs OFF
jayanthd
Joined Jul 4, 2015
945
You will have to change the PWM amplitude to get what you want.
Input PWM duty can vary from 0 to 100% and input PWM frequency can vary from 50Hz to 1KHz. This range of signal needs to be converted to DC voltage in the range of 0-5V for adc input and the after reading the adc voltage it has to be converted to pwm duty value and assigned to output pwm duty.
jayanthd
Joined Jul 4, 2015
945
According to LesJones circuit if frequency is high then voltage will be less and for low frequency voltage will be high. Right ?
RenesasT1
Joined Jul 6, 2017
107
Hello Jayanthd,
the frequency is 100Hz (88% duty)
I have used 3.3uF and 10k ohm resistor, but the o/p is not pure dc and its fluctuating.
The o/p voltage is 3.6V
jayanthd
Joined Jul 4, 2015
945
Hello Jayanthd,
I am not sure but can you increase the capacitor value and decrease the resistor value and try ?
