I'm looking for a timing cct which will be triggered by a PWM signal (Radio Control equipment) to close a NO relay for 6 seconds or so, with the PWM signal still on, the timer and relay can reset when the signal is removed. Power input from receiver is 5-6 volts enough to drive the relay coil. I can't seem to find a cct that specifically address this requirement. I have no design aptitude, but can copy, build and test, so very reliant on any help, please, many thanks in advance
