PWM question
Status
Not open for further replies.
mines
Joined Feb 9, 2011
16
Hi I am building a high current PWM for H2=O generation. I'm using a linier power supply that I built from rewiring a microwave transformer, a bridge rectifier and a couple of caps. I've got 17 volts at 30+amps. I'm not at all good at design yet. I found a nice schematic for HHO generation but have a couple of questions bugging me. Down stream of the load he is using bank of Mos-Fets for the modulation. I've built a pretty good driver using a 555 that I'm able to vary both the duty cycle and on off time. I intend marry this in to the Mos-Fets he uses to actually pulse the load. He advises the use of Schotty diodes in parallel to the Mos-Fets. My question is why are they there and how do I calculate the size of them? My text books tell me what they are but not how to apply this knowledge.
SgtWookie
Joined Jul 17, 2007
22,230
PWM works great when you want to do things like dimming lights, heat control, motor control, etc but not so well for your purpose, when it's just pure PWM. There's nothing to limit the maximum current except for the resistance of the wiring and the MOSFETs when they are turned ON, and when they are OFF, there is no electrolysis action; so with PWM you are toggling between two undesirable states.
You really need a current-mode PWM controller with a heavy-duty inductor that keeps the current relatively constant.
mines
Joined Feb 9, 2011
16
OK Sargent As I have gotten this far can you point me in the right direction to fabricate a good heavy duty inductor? And also Why the heck are those Scotty diodes there?
I'm so glad that you guys are here and willing to share your knowledge with me.
#12
The Shottky diodes are to protect the mosfet from having the wrong polarity applied to it. Where you're going to get the wrong polarity out of a 12 volt battery also escapes me.
SgtWookie
Joined Jul 17, 2007
22,230
Sorry, I'm not on the Board much recently; my life has become quite busy in the last few years.
You haven't given a target current yet; what kind of current do you want to maintain through your load?
For lots of reading material on switch-mode power supplies, go here:
http://www.smps.com/
For something rather simple/basic, which also serves as an excellent tutorial, have a look at Ronald Dekker's site:
http://www.dos4ever.com/flyback/flyback.html
Now, a flyback converter is not what you need for YOUR project; they're only good for up to around 150 Watts. However, it gets you started on switch-mode power supplies that you can build relatively easily, and you gain valuable experience by making your own inductors/transformers using salvaged (or new, if you wish) materials. The thing is, without such experience and knowledge, you will be quite lost when trying to design/build/troubleshoot a current-mode SMPS.
35,093
The Schottky diodes are there to protect the driver transistors from back emf if your load has inductance. If the load is purely resistive then you would not need the diodes.
Also many power MOSFETs have the diodes built in.
Status
