Hi all,
what breadboard IC's do you recommend for interfacing 3.3V (Arduino Due) PWM signals with 5V motor driver ?
I also have I2C, SPI, UART devices to connect.
Due is able to send 1Khz PWM signals . I have no schematics of the motor driver since I cannot find them online. Its the Riorand ZS-X11H .
Can I use mosfets to control break direction and stop from Due to driver? The driver provides feedback to calculate the RPM, would I be able to read it?
The reason I chose Due over other boards is:
I have done a research and posted this question in several forums including the Arduino forum but I still havent come up with a solution
- a) I have a lot of devices (and probably will add more) and
- b) Clock speed Due is twice as fast as my second choice (MKR1010)
