Some motors can draw very high current at zero speed (stall current). If your ESC or battery can’t handle this, the voltage collapses.When I connect the BLDC motor and ESC to the PWM input, the signal works well. However, when I attempt to start the motor by connecting the battery to the ESC, the PWM signal collapses, and the motor does not operate.Help me with a solution........
i am not using the propellers for now and still the motor is not workingSome motors can draw very high current at zero speed (stall current). If your ESC or battery can’t handle this, the voltage collapses.
If possible, test the ESC and motor with a smaller load or a propeller removed to see if it spins.
