PWM amplification 0-3.3V to 0-24V
Noname Nononamename
Joined May 14, 2018
9
Hi there. I want to amplify multiple PWM signals generated by a 3.3V MCU. The system specifications are:
  1. Input: PWM frequencies up to 1Mhz and fixed duty cycle 50%.
  2. Output: 0-24V (don't care if inverted) and sink/source current ~10mA or more. Also trise,tfall must be reasonable small <50ns.
  3. ICs with multiple channels should be used in order to save space.
I have searched for anything that would do the job (buffers, line drivers, mosfet drivers etc) but nothing matches the specs needed.
The best choice till now is SN7407 but it has open collector output and not push-pull. Also CD4041UB could be a good choice but it support only up to 18V. Can someone please suggest a specific IC or at least what type of ICs to search? Thanks in advance :):)
Noname Nononamename
Joined May 14, 2018
9
Thank you for your response! :):):) I have also looked for level shifters (nothing above 18V) and for comparators (nothing above 16V with push-pull output). Any other suggestions?
dl324
Joined Mar 30, 2015
18,449
If your requirements exceed the specs of any available parts, you'll need to roll your own. Your sub 50ns rise/fall time will be problematic.
PWM with a fixed duty cycle doesn't make much sense to me.
Noname Nononamename
Joined May 14, 2018
9
Yes I know that fixed duty cycle seems strange but this is how it is. I mentioned it cause I thought it could make the solution simpler. Thank you for your answers, I will keep searching for a solution. However, I would appreciate it if someone else could suggest a different solution.
22,106
Correct me if I am wrong but this has open drain outputs and the max output high level current is only 1μA.
The outputs are open collector. The output high current is controlled by the size of the pullup resistor and the load impedance, not by the device itself. So use the comparator output to control either a high-side or a low-side switch depending on your load.
Noname Nononamename
Joined May 14, 2018
9
From datasheet "The open-drain output allows the user to configure...". But it doesn't matter if it is open drain or open collector because I cannot use pull up resistors. I want push/pull outputs. If I wanted to use pull up resistors I could just use SN7407, as I mentioned in my first post. Thanks for your response.
Noname Nononamename
Joined May 14, 2018
9
Thank you very much for your response. Unfortunately this chip doesn't meet the speed requirements. For push-pull mode the typucal t-rise is 500ns and t-fall is 50ns. The best solution would be something like the TC4427, but capable for higher supply voltage (only 18V) and more inputs-outputs for less cost/space. The only IC that seems to meet the requirements is IX4427, but it has only 2 channels.
danadak
Joined Mar 10, 2018
4,057
That's of course into 100 pF from spec sheet, timing that is.
Do you need to switch the load to the 24 VDC or is that the load supply buss,
and all you need to do is to get enough current thru load ? If latter use a zener
I series with output to drop output V driver sees ?
Just a thought.
Regards, Dana.
Noname Nononamename
Joined May 14, 2018
9
No, I need just a push/pull 0-24V ~10mA <50ns output. I could do this by many means but the problems come out when someone wants to do it for multiple signals in a small board. I think the zener would fix a problem that does not apply in this situation. Regarding the trise/tfall of the driver you suggest, I don't think that smaller capacitance would make huge difference. My opinion is based on a similar simulation using the TC4427, where decreasing capacitance didn't make much difference to the trise/tfall.
