Hi there. I want to amplify multiple PWM signals generated by a 3.3V MCU. The system specifications are:
The best choice till now is SN7407 but it has open collector output and not push-pull. Also CD4041UB could be a good choice but it support only up to 18V. Can someone please suggest a specific IC or at least what type of ICs to search? Thanks in advance
- Input: PWM frequencies up to 1Mhz and fixed duty cycle 50%.
- Output: 0-24V (don't care if inverted) and sink/source current ~10mA or more. Also trise,tfall must be reasonable small <50ns.
- ICs with multiple channels should be used in order to save space.
