putting a zener in parallel with a 7805
mikewax
Joined Apr 11, 2016
230
hi guys,
i got one of those Bird-style electric scooters and i want to replace the battery pack of 29.4V with a bigger pack of 37.8V.
my problem is that the scooter's motor control unit has a uController, which runs off of a ST L78M05 regulator. i looked up the regulator and it turns out that it can regulate from an input of no more than 35v. if i give it an input of 37.8v it's bound to fail before long.
so what if i get a 30 volt zener and solder the anode of the zener to the input pin of the regulator, the cathode of the zener to a resistor, and then connect the other end of the resistor to ground?
i'm estimating the load on the 7805 regulator at no more than about 50mA.
Papabravo
Joined Feb 24, 2006
22,116
hi guys,
Compute the power dissipation as (30-5)*0.050 = 1.25 watts. You're going to need a pretty good heat sink or it will pop. Try a buck regulator.
ElectricSpidey
Joined Dec 2, 2017
3,370
hi guys,
That won’t work.
I would place a properly rated Zener in series with the positive input of the regulator instead.
Say 5 volt 1 watt…assuming the current requirement is as you said. You could also use a 5 watt Zener if you have any doubt.
mikewax
Joined Apr 11, 2016
230
so that's why the existing regulator is a DPAK. a buck would certainly be better but i'm just tryin to do the quick n dirty solution. ideally i would be able to unsolder the 7805 from the board and just get another higher-rated one. but that's not an option with such a small board.
thanx
danadak
Joined Mar 10, 2018
4,057
If you have Iz =x, Vz = y, then P = Iz x Vz.
At 50 mA, say Vz 5.1V, that only 255 milli watts. 1/2 W Zener would be fine.
Regards, Dana.
