I'm trying to connect an sd card to the stm32f091cct6 microcontroller using FatFs driver. After sending some clock while MOSI and CS are high, I send idle command (CMD0) but receive no response from sd card. I pulled up MISO pin with a 100K resistor and clk pin with a 10K resistor. sd card isn't dead because I tried to communicate with it with another processor (TI ARM cortex M3) and it was a success. I pulled up all signals interally. (I tried different configurations of internal and external pull-ups but nothing happend). This is spi initialization code:
/* SPI Config */
heval_Spi.Instance = EVAL_SPIx;View attachment 138412 View attachment 138413
// PCLK1 = 48MHz
heval_Spi.Init.BaudRatePrescaler = SPI_BAUDRATEPRESCALER_64;
heval_Spi.Init.Direction = SPI_DIRECTION_2LINES;
heval_Spi.Init.CLKPhase = SPI_PHASE_1EDGE;
heval_Spi.Init.CLKPolarity = SPI_POLARITY_HIGH;
heval_Spi.Init.CRCCalculation = SPI_CRCCALCULATION_DISABLE;
heval_Spi.Init.CRCPolynomial = 7;
heval_Spi.Init.DataSize = SPI_DATASIZE_8BIT;
heval_Spi.Init.FirstBit = SPI_FIRSTBIT_MSB;
heval_Spi.Init.NSS = SPI_NSS_HARD_OUTPUT;
heval_Spi.Init.TIMode = SPI_TIMODE_ENABLE;
heval_Spi.Init.Mode = SPI_MODE_MASTER;
SPIx_MspInit(&heval_Spi);
HAL_SPI_Init(&heval_Spi);
I've attached spi signals
yellow: MISO
cyan: CLK
purple: MOSI
blue: CS
