put a low state with 12V signal, without rele or optocoupler
ponferrada
Joined Feb 28, 2019
9
Hi all,
I have the next circuit to conform a signal reset which is a low state signal, I do that pressing SW1.
Now, I would like to conform the signal reset when an external 12V signal comes, I would like to do that with a more elegant solution than using a relé or an optocoupler.
some idea to do that simple and easy?
thank you all
Picbuster
Joined Dec 2, 2013
1,062
use a voltage divider and clamp output to vdd to protect input.
From 12V to 2.5 take 10K and 2.4K ==> 1 mA approx
center 10K & 2.4 clamp via fast diode to vdd.
if however the system can't handle currents (Via 10K) higher than 1 mA then take 100K and 24K but you have to change C51 ( to get the correct rc time).
Picbuster
Picbuster
Joined Dec 2, 2013
1,062
Hi all,
thank you all
This should work (or function).
Picbuster
