Hello, after researching i found out that its actually better making push-pull stages with MOSFETs
In this configuration i put both of the drain in common, and i changed the input ( square wave ) to 0-12.
Do u guys think this design Is fine? i will be able to drive the gate of the MOSFET at 1A? ( I didnt put any series resistor should i put one (?) )
In case how i should change my circuit?
The components i chose are : IRLZ44N and IRF9530 for the totem pair
While the MOSFET that will be driven is: IXTH360N055T2
