Push Button Selector Switch (No ICs)
iimagine
Joined Dec 20, 2010
512
So I got bored and decided to see if i can come up with a circuit that can have multiple switches and only turn on the one that is selected. Only one switch can be on; push button style.
I came up with a working circuit, it simulates well. I'm posting it to see what everyone think.
Description:
Yellow box: One shot circuit
Blue box: Latch on
When a button is press, a quick one shot pulse is fired and resets all switches to off, leaving only the one thats being pressed on. Can have as many buttons as you want :)
RPLaJeunesse
Joined Jul 29, 2018
264
When one considers real-world leakage (collector-base, PCB, source-drain, etc.) at higher temperatures you may find your resistor values are excessively high, especially the 10M one. The BJT might need a pullup on the emitter.
38,832
It's an interesting design exercise, but generally too complicated and expensive to build versus much simpler circuits using ICs.
RPLaJeunesse
Joined Jul 29, 2018
264
Implemented in a way that is extendable to more than 2 selections, it is a 2-transistor latch, albeit per switch. The logic term for such an implementation is "one hot" coding.
RPLaJeunesse
Joined Jul 29, 2018
264
Looks like it should work, provided the supply voltage is well above the sum of Vgs(on)(PMOS) + Vgs(on)(NMOS). Otherwisewhile a switch is closed saturated switching might not occur.
