I have an existing circuit which controls a pump motor. A PLC output energizes the control voltage to turn the pump on.
A timing relay allows the motor to start for 10 sec. then opens the circuit.
A flow switch contact is in parallel with the relay contact to hold in the circuit as long a flow is active.
When flow stops, the control circuit is opened.
My problem is that the circuit then tries to restart and the start sequence is initiated again.
How can I add a reset into this circuit, when it has no power until the PLC tells it to start.
