Pulsing 4026B 7 seg driver with PIC and it won't work.
Lynda Somerville
Joined Mar 13, 2018
2
Hi!
I'm working on a circuit using a GENIE E18 to pulse a 4026B and get a count. The problem is the clock does not seem to be registering the pulse. I've run the signal through a TIP121 transistor. Could this be the problem? I've done this a million times with a 555 and it's been fine. Could it be something to do with the PIC signal itself? I've checked the 4026B spec but I'm no more enlightened.
It's working fine in simulation using Circuit Wizard.
Any help greatly appreciated.
ebp
Joined Feb 8, 2018
2,332
The ULN2803 is an open-collector driver. To assert a valid logic 1 a pullup resistor is required (i.e. a resistor of perhaps 10 k, value not too critical here, between the output and V+). I don't understand what the TIP121 is for - that's a power transistor.
ebp
Joined Feb 8, 2018
2,332
I found a schematic of a Genie E18 project board that has a 2083. Perhaps that is not the board in use. More info required.
Lynda Somerville
Joined Mar 13, 2018
2
Thanks for the advice. Was recommended the TIP121 but now see the issue. I actually have a ULN2803 in the circuit for some relays that the GENIE is also driving so that will work well. I’ll let you know how I get on.
Thanks again!
