Pulse generation with hall effect sensor
LowQCab
Joined Nov 6, 2012
5,102
This Post seems to make no sense.
A more extensive explanation of what You are trying to accomplish,
and, information on the type, and purpose of the Engine is needed,
as well as a Schematic showing the connections to the Hall-Sensor.
Was the Engine originally equipped with a Carburetor or Fuel-Injection ?
bwalya chikubula
Joined Sep 19, 2024
The end was originally equiped the a carburetor and a trying to modify it to a single throttle body injection,I want to use that circuit diagram but I don't know where I can connect the pin from a hall sensor output,or do I also need to cut out the volume controller.
LowQCab
Joined Nov 6, 2012
5,102
Fuel-Injection using the provided Circuit will NOT work.
You will need something like a "Micro-Squirt" Fuel-Injection-Computer, ( around ~$300.oo in the USA ),
and since You will have to program it Yourself with a Laptop-Computer,
this will also not work,
because You do not yet understand exactly how, and why, an Engine works.
The Engine will not run using such a simple Circuit.
LowQCab
Joined Nov 6, 2012
5,102
Also, fuel injectors do not work at 12VDC, but rather at more than 100VDC. At least in most engines.
That's only for "Direct-Injection" Injectors that spray directly into the Combustion-Chamber,
and most use around ~60-peak-Volts, with PWM-"hold-open"-Current-Limiting.
Even Direct-Injection Injectors are still designed to "hold-open" with 12-Volts.
Diesel-Electronic-"Common-Rail"-Injectors are more "heavy-duty" and may require higher peak-Voltages.
cmartinez
Joined Jan 17, 2007
8,854
Yeah, most of my experience with injectors has been with Diesel engines.
