Pulled terminals
Churator
Joined May 17, 2017
I'm trying to fix baby camera, where the Infrared LED is not working.
It's a 850nm 1W led if that matter
I've mistakenly pulled the terminals that connect the led to the PCB
how can I trace them ?
Second question: Part of the led still stuck there, I've tried heat gun, Iron, knife, its stuck. Any suggestions ?
wayneh
Joined Sep 9, 2010
18,184
My first suggestion is a question: How do you know the LED was bad to begin with?
Those ripped up traces would be sought to repair but you might be able to simply hard wire - with pieces of wire - to bypass the broken area. To do this, you'll need to find where the traces went and a spot where you can attach a wire. It's not impossible to repair traces with various techniques, but it's far easier to just bypass the break if you can.
The LED was likely attached to that aluminum piece with heat sink material, possibly an adhesive. Do you have the new LED in hand? It's a little hard to tell from the photo just what needs to come off the board and what should stay.
#12
Joined Nov 30, 2010
18,224
Trace repair: scrape the protective coating off and bridge the crack with one or more tiny wire strands, then solder them down, or...connect a wire to the good side of the break and run the wire straight to the LED.
I'd be helping more, but I'm stumped. I have never seen that kind of LED mount.
Churator
Joined May 17, 2017
Its open on both direction, and won't light up on 5V inline, so I could only guess.
I've tried to trace the circuit and hardwire it, but I can't find the trace :(
The mount is just stuck there :(
R!f@@
Joined Apr 2, 2009
10,014
1W Led needs to be heatsinked.
The body of the LED is soldered to the PCB tracks to dissipate heat.
You need heat to take it out.
use a Hot gun to heat without heating the surrounding too much and then you can lift the broken LED.
